combinational division by 3
krishanu007
Member level 2
Bangalore,India
Hi all,
I want a circuit which will combinationally divide a number by 3.(or in one cycle :idea
whats is given is that number will always be divisible by 3 only.:razz:
post any tutorial link or any helpful post..as I couldnt find any moderate one.
Hi yx.yang
any idea what it will synthesize ? I mean what algo will be used in compilers for synthesis.
reg [7:0] divider;
wire [6:0] div_result;
assign div_result = divider / 3;
---------- Post added at 09:55 ---------- Previous post was at 09:43 ----------
Hi yadavvlsi,
I was reading this article & found it is a clock divider circuit,if I am not wrong.
I am sorry if I couldnt make it clear to everyone,I want a divider circuit for dividing a number by 3.as we do for divide by 2,right shift by 1.
one half-way solution:
you would notice that
1/3 = 1/4 +1/16 + 1/64 + 1/256 + .. (to infinity)
So you could get an approx result by doing shift-by-2 many times and adding up.
- b
...and further refine by dividing the difference of above result*3 from original number by3 (using a look up table) and adding to above result (all if numbers involved are small 16-bit or so)
-b
Hi yx.yang
For synplify and synopsys DC or Candence RTL compiler, the assign div_result = divider / 3 can be synthesised. While for xilinx XST tool, you can just instance the xilinx generated divider IP core (like memories)
