Pay attention to the linearity if it is a spec for the system and it seems that the gain is not that high.Maybe u need to consider change the matching network structure.
For best stability you should use RL feedback network from C to B
you can also use a series resistor in B which will of course reduce your gain.
the efficiency in real circuit also depends on what type of cap are you using at the output.
using alko caps is very helpfull which has a very low Er,ur
Resistor in series with the gate is a cheap fix.
Even if this circuit is a driver, it will increase the Noise Figure and indirect the final Noise Power.
Try this matching network (beware V1 is -0.9V)
