Tuning OMN of PA
Christmas_N
I am designing a PA Class-F circuit but having difficulty with OMN, I want to find someone to help me fine-tune the circuit, because 3f0 is at high frequency, the EM simulation results are not as good as I expected. I hope someone can help me and I will pay for it.
If you post here the schematic and your expectations, you might get a free solution..
Thanks for your reply, here is the schematic and simulation of schematic
But when I layout and simulation EM, in third harmonic is not good, I show below:
I think this is because high frequency leads to large attenuation and parasitic components. How to improve this?
You're working at 9GHz and you used GJM series consumer type capacitors. These capacitors are not modelled at 9GHz and beyond. You have to use appropriate capacitors for professional purpose.
Look at
and
https://www.johansontechnology.com/rf-capacitors
Are TL48 and TL10 Open Circuited Stubs ?? If they are, why don't you use Open Circuited Stub MS Line ?
Models might be very different. I mean opening a MS Line cannot transform that line to Open Circuited TL.
Because the simulator uses the models that have been obtained either analytically or empirically.
Layout is also important. How did you design the layout ??
You cannot simulate (and tune) the OMN of a Class-F PA without the transistor in place. Especially at this relative high frequency.
