Calibre PEX errors about matching terminal and cell mapping
yhq0413
Junior Member level 1
I run calibre PEX with some warnings and errors
Warning: Not creating terminal GND in (vco calibre) since matching terminal was not found on schematic
Warning: Not creating terminal VDD in (vco calibre) since matching terminal was not found on schematic
Warning: Not creating terminal OUT in (vco calibre) since matching terminal was not found on schematic
Warning: Not creating terminal VIN in (vco calibre) since matching terminal was not found on schematic
error: could not find cell mapping for device n18_ckt-rf .Ignoring instance M0
error: could not find cell mapping for device p18_ckt-rf .Ignoring instance M1
the I/O type is inputoutput
I want to obtain an extracted view "caliber-view"
the process is SMIC 0.18 RF
virtuoso version is 5033.
datone520
Junior Member level 3
China
Re: calibre PEX errors
I meet the same provlems with you
---------- Post added at 04:47 ---------- Previous post was at 04:45 ----------
hi yhq0413,
have you solve your problems ?could you please share your experience ?my email :lyh20041016@yahoo.com.cn
kgl_13gr
Member level 5
The first errors are clear. Check why the respective terminals are missing in the schematic.
Also, there is an option during PEX or calibre view creation that allows you to create all terminals, that is even if they are missing in the schematic.
However, I would be cautious with that, as it maybe goes around the problem.
Have you passed LVS?
datone520
China
yes ,lVS have passed
---------- Post added at 13:10 ---------- Previous post was at 12:55 ----------
my problem is like this ,because the net name in my layout are capitals ,but in schematic ,it has small letters and capitals .just look at the pic1 and pic2
when I use calibre2009 to extract rc ,and get calibre view ,the warning :
o NOTE: Creating CalibreView for cell SAR14_TOP2_Analog ...
\o WARNING: Not creating terminal RAMOUT in (SAR14_TOP2_Analog calibre_switchleft18) since matching terminal was not found on symbol.
\o WARNING: Not creating terminal VREF in (SAR14_TOP2_Analog calibre_switchleft18) since matching terminal was not found on symbol.
\o WARNING: Not creating terminal SWITCHLEFT<18> in (SAR14_TOP2_Analog calibre_switchleft18) since matching terminal was not found on symbol.
\o WARNING: Not creating terminal SWITCHLEFT<17> in (SAR14_TOP2_Analog calibre_switchleft18) since matching terminal was not found on symbol.
\o WARNING: Not creating terminal SWITCHLEFT<16> in (SAR14_TOP2_Analog calibre_switchleft18) since matching terminal was not found on symbol.
\o WARNING: Not creating terminal SWITCHLEFT<15> in (SAR14_TOP2_Analog calibre_switchleft18) since matching terminal was not found on symbol.
\o WARNING: Not creating terminal SWITCHLEFT<14> in (SAR14_TOP2_Analog calibre_switchleft18) since matching terminal was not found on symbol.
\o WARNING: Not creating terminal SWITCHLEFT<13> in (SAR14_TOP2_Analog calibre_switchleft18) since matching terminal was not found on symbol.
\o WARNING: Not creating terminal SWITCHLEFT<12> in (SAR14_TOP2_Analog calibre_switchleft18) since matching terminal was not found on symbol.
\o WARNING: Not creating terminal SWITCHLEFT<11> in (SAR14_TOP2_Analog calibre_switchleft18) since matching terminal was not found on symbol.
Then I use cadence AMS tool to do post simulation ,when netlister ,erros appears:
*** Re-Netlisting the entire design.
*** The netlisting will be done using connection by name
*** ( Explicit
connections) for all the stopping cells and non-stopping cells.
ERROR: Netlister : member terminal 'SwitchRightL<8>' of instance 'I5' in cell
'SAR_test_C_mismatch_backend_simu_full' view 'schematic' : cannot be found in
the switched master of the instance.
ERROR: Netlister : member terminal 'SwitchRightL<7>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchRightL<6>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchRightL<5>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchRightL<4>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchRightL<3>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchRightL<2>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchRightL<1>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchRightL<0>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchLeft<18>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchLeft<17>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchLeft<16>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchLeft<15>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchLeft<14>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchLeft<13>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchLeft<12>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchLeft<11>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchLeft<10>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchLeft<9>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchLeft<8>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchLeft<7>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchLeft<6>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchLeft<5>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchLeft<4>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchLeft<3>' of instance 'I5' in cell
ERROR: Netlister : member terminal 'SwitchLeft<2>' of instance 'I5' in cell
*** Library - sardig_top_0916b, Cell - tb_saradc_digital, View - functional
*** Module port ordering for lib sardig_top_0916b, cell tb_saradc_digital, view
functional will be
*** done using the user specified port order as follows:
("ramout" "din" "sample" "offset" "overdrive" "left_code<16:0>"
"right_low<8:0>")
---------- Post added at 13:15 ---------- Previous post was at 13:10 ----------
the picture above is the layout ,net format is bus signal lines .
so ,how can I get the right calibre view when my desin has bus signals ?
---------- Post added at 13:20 ---------- Previous post was at 13:15 ----------
thanks and reguards
