Spring-loaded pins are rapidly finding new applications in modular product design. Also referred to as SLCs (spring-loaded connectors), this product resolves many of the manufacturing issues like misalignment, coplanarity, and tolerance stack up that can plague traditional pins and sockets...
The Emergence of Power Integrity Analysis
As the speed of the data signal increases, many reasons including power supply noise lead to the degradation of the high-speed signals. In low power high-speed digital interfaces, it is crucial to characterize the whole system power supply in order to...
In this blog post i will share the OLED libraries with you, which are written for mikroC compiler and can be used with any other C compiler.
Following are the functions which are currently present.
void OLED_Init( void );
uint8_t OLED_Width( void );
uint8_t OLED_Height( void );
void...
Time Domain Reflectometry is the analysis of conductor lines (interconnects)by sending a pulsed signal into the conductor and then examining the reflection of that pulse. A TDR transmits a short rise time pulse along the conductor. If the conductor is of a uniform impedance and is properly...
The following attached file contains an SSH Client extension
which I made for my own use, but it may also be useful for users of the MIT Application Inventor 2 (AI2) community, or even to the AppyBuilder community (code intrinsically compatible for the last one, but not tested). This is just the...
Biochemical analyzer, abbreviated as bioanalyzer, primarily provides various clinical biochemical, hematological, and immunological testing projects for all levels of hospitals in the field of laboratory medicine.
It is used to test clinical biochemistry indicators such as liver function...
Forlinx Embedded and SemiDrive have teamed up to launch the FET-D9360-C System on Module(SoM), a high-performance industrial processor based on the D9-Pro processor.
This SoM is designed to meet the growing demand for high-performance, reliable, and stable computing in the industrial sector...
Discover how gateways, exemplified by the Forlinx Embedded FCU2601, are revolutionizing energy consumption systems.
From real-time monitoring and intelligent analysis to remote control and security protection, these gateways serve as the "intelligent brain," optimizing energy management and...
Discover how underground inspection robots are revolutionizing pipeline maintenance, ensuring efficient and accurate monitoring of underground utility networks.
Learn about the cutting-edge FETMX8MP-C SoM's role in intelligent inspection technology.
More info...
Exciting news for tech enthusiasts! The #Allwinner T113-i embedded processor makes waves with its powerful dual-core Cortex-A7 CPU, 64-bit XuanTie C906 RISC-V CPU, and HiFi4 for top-notch computing and decoding capabilities. If you're into cutting-edge technology, this is worth checking out...
The OK7110-C's screen timing requires the dedicated calculation tool starFive_DSI_Tool.exe, which is stored in the Tools/dsi_tool folder of the user profile.
Operation methods:
01 Parameter configuration
Modify the input.ini file, which is used to configure the screen parameters; the following...
According to Maxtech International data, the global civil infrared market size will exceed 7.6 billion US dollars in 2023, and in the past four years, the infrared industry has maintained a growth rate of over 11%. Moreover, according to data from Huajing Industrial Research Institute, the...
Amazon recently announced its plan to use drones to deliver packages in the UK by the end of 2024. Amazon has been investing in drone technology for a decade now, but currently, its drone delivery services are limited to a few regions and primarily cover the delivery of non-pharmacy products...
This solution employs Lontium Semiconductor's LT8912B, which features a single MIPI D-PHY receiver with four data lanes, each running at speeds of 80Mbps to 1.5Gbps, with a maximum input bandwidth of 6Gbps.
LVDS has 1 clock lane and 4 data lanes for a maximum of 1.0 Gbps per data lane. The HDMI...
Linux Each device on the system has its own set of fixed rules for operation, and there are numerous types and models of devices. It is not practical or meaningful to write the fixed rules for each device into the kernel.
Each device has its corresponding driver to ensure it can operate...
There are several methods to configure the Linux kernel, and one of them is using the text menu-based configuration interface called "make menuconfig", which provides an intuitive and straightforward way of configuring the kernel.
1. Components of the Linux Kernel Configuration:
Configuring the...
In today's complex embedded Linux application scenarios, breaking down barriers between different platforms is crucial for efficient cross-platform file sharing. In this blog post, we will guide you through the process of setting up Samba service on the Allwinner T507-H powered OKT507-C...
Multi-axis robot control refers to the process of controlling the motion, position, and tasks of robots with multiple motion axes or joints. Multi-axis robots are typically comprised of multiple motors and joints, allowing them to move and perform various tasks across multiple degrees of...
As technology develops rapidly, smart devices play an increasingly important role in our lives. Have you ever wondered why your smartphone, computer, and other smart devices can run various complex software and applications? This is all thanks to the powerful processor architecture. Today, we...
Road sensors are mainly used to collect data information on road conditions and provide raw data for the roadside sensing network. The requirements for intelligent transportation are developing towards informationization, intellectualization, real-time, and accuracy, and the perception of road...
Saving existing data and avoiding data loss when dealing with sudden power loss is crucial for users of fast storage and acquisition data products. There are many solutions to this problem, among which ferroelectric memory (FRAM) is a good choice. FRAM is a non-volatile memory with fast write...
With the development of network technology, there is an increasing demand for storing video data over the network. As a result, surveillance systems that were previously centered around DVRs (Digital Video Recorders) have further evolved into NVR (Network Video Recorder) systems with network...
This article will introduce the method to implement USBNET mode using the Forlinx Embedded OK3568-C development board. Before that, we need to know what is USB Gadget.USB Gadget refers to an electronic device that is developed to connect to a host via USB in USB peripheral mode.
For example...
Robots can be broadly divided into three categories: industrial robots, service robots, and special robots. Although the market size of special robots is relatively smaller than the other two, with the accelerated evolution of new technological and industrial transformations, the deep...
The robot control system is a core component of modern robotics technology, enabling robots to perform various tasks and actions, ranging from industrial production to healthcare and even household services. The robot control system is like the brain of the robot and is the primary component...
The Forlinx OKMX8MP-C development board is equipped with two native CAN buses. However, in certain product development scenarios, there is a need for additional CAN buses. This article will introduce a method for SPI to CAN conversion, providing engineers with a reference.
Description
• The...
Automated Guided Vehicles (AGV), also known as unmanned transport vehicles, are characterized by their significant feature of unmanned driving. AGVs are equipped with an automatic guidance system, which ensures that the system can automatically travel along a predetermined route without the need...
Agricultural plant protection UAVs are advanced technologies used in the agricultural field. They utilize unmanned aerial vehicles (UAVs) or remotely controlled aircraft, along with various sensor technologies, to monitor, diagnose, and manage crop health, aiming to improve the efficiency and...
Roadside Unit (RSU) is a communication gateway deployed alongside roads and serves as an essential component of the V2X roadside system. Its function is to collect real-time information regarding traffic, road conditions, and vehicle flow. This information is then transmitted through...
An embedded Single Board Computer is a complete circuit board that integrates a processor, memory, interfaces, clocks, and other auxiliary circuits. It is commonly used to create embedded systems, such as those used for controlling robots, automobiles, or industrial equipment.
Here is an...
With the development of global smart manufacturing, embedded boards and other smart devices are widely used in various fields. However, with the dramatic increase in the number of devices, various interference signals in the environment also increase, which poses higher requirements for the...
OK-MX9352-C Single Board Computer
1. NTP Synchronization Time
The iMX9352 chip supports the Network Time Protocol (NTP) synchronized time function, which allows users to obtain time information from an NTP server by entering the NTP command at the terminal. NTP timing can be easily achieved by...
This article applies to the Forlinx OK-MX9352-C platform with Linux 5.15.52 operating system.
How to change the root account and password for logging in to the Single board computer?
root@ok-mx93:~# passwd root //Modify root password command
New password://Enter the new password (The...
Forlinx Embedded OKMX8MP-C EVK is developed with NXP i.MX8M Plus high-performance processor with AI computing power up to 2.3TOPS to meet lightweight edge computing needs. At the same time flexible I/O interface configuration and advanced rich multimedia resources to facilitate customer...
Although there is only one network port on the Forlinx Embedded OKA40i-C EVK, the Allwinner A40i-H processor has two network controllers, so there is a dual network port solution in the datasheet offered by Forlinx Embedded. Engineers may encounter some NIC design problems. We will share three...
HMI is the medium for interaction and information exchange between the system and the user, and HMI continues to evolve as technology advances. New interaction modes will be added to future HMI in addition to the three basic functions: control, data collection, and display to enable machines to...
The Forlinx RK3588 evaluation kit integrates an embedded Mali G610 3D GPU with support for OpenGLES 1.1, 2.0, 3.2, OpenCL 2.2 and Vulkan 1.2. The special 2D hardware engine with MMU can maximize display performance and provide very smooth operation. In this article, we will test the performance...
The OKT507-C from Forlinx Embedded is a popular EVK with various interfaces. The OKT507-C's CPU does not have so many pin resources, so how does it provide various interfaces? The key point is IO Extended Chip—TCA6424A.
It is a 24-bit I2C and System Management Bus (SMBus). Inputs and outputs...
【Lansheng Technology Information】STMicroelectronics' STL120N10F8 N-channel 100V power MOSFET has extremely low gate-drain charge (QGD) and on-resistance RDS(on), and the figure of merit (FoM) is higher than that of the previous generation of similar products Increased by 40%.
The new MOSFET...
01 Multiplexing GPIO
1.1 Adoption of the Iomux Method
1.SD2_DATA01 is used as GPIO.
First look in OKMX93-linux-kernel/arch/arm64/boot/dts/freescale/imx93-pinfunc.h
The specific parameters here are not described anymore. Please check the corresponding registers in the...
