Audio Amplifier. Which class should I use?
oscilloscope also tells voltage. so can we take same job with voltmeter too. So can I use voltmeter in order to measure output?
Because my PC is not branded. I brought parts separately and attach them in this way I made my PC at home. So I can't ask it to the designer company Because I don't had any designer for my PC
Of course not . the voltmeter didn't design for frequencies above 50 or 100 HZ . and it can't show you variable waves too . ( un sinusoidal waves ) .
Now I am confused how to do next. I think I should terminate my project until I don't have oscilloscope.
BTW: What is your max output?
NO no no ,
It doesn't matter , i'll tell you the standard value i should measure it again .
Really. Oh thank ***. I am hoping again. Thanks a lot. :) Thank you goldsmith. You are very helpful.
So what should we do now?
Hi shayaan
Sorry for this delay to reply .
Well , when i measured it , the out put at maximum amplitude was around 2 volts . so , can you predict the required gain ?
Best Wishes
Goldsmith
Its OK sir.
Formula for gain is:
Av=Vo/Vi
I know Vo=2V. But What is Vi? I think input is mains i.e. 220V
Its OK sir.
Av=Vo/Vi
Why 2 volts as out put ? it is input of your amplifier . the out put of PC will be around 2 volts . and you need 50 watts . so , what will be the required gain , that can change 2 volts to the 50 watts ? what will be the out put amplitude of your amplifier ?
So
Power is given as
P=(Av)(Vi)
Right?
So It should be look like that
Av=P/Vi
Av=50/2
Av=25
Right?
Definition of power is volt into current.
P=VI
I need to calculate gain i.e. Av
Av=Vo/Vi
And
P=VI
I have given Po=50W and Vi=2V
Sir I am unable to see any relation between output power and input voltage.
Kindly help me out of this.
I have these three formulas
Av=Vo/Vi
Ap=Po/Pi
Ap=Av*Ai
I think you are asking for voltage gain.
Humm , see below , please , this site told good things regarding real power :
https://www.davidbridgen.com/Amplifier power vs voltage.htm
https://www.davidbridgen.com/power.htm
So , now what do you think ?
And yes i'm talking about voltage gain !
Another thing ! i want that you learn that when you have 2 volts as vin what should be the value of voltage across the load ,to achieve your desired power ! don't forget that we will have a buffer ( complementary stage ) after this voltage amplifier .
So You mean I should read all this stuff and understand? Then you will move further?
Of course yes ! the pages that i suggested , are just two interesting and simple page .it will help you to understand ( better understanding because of good diagrams )
Then i'll guide you to continue , because my first aim isn't this that you just build an amplifier . i want you be able to design all kind of relevant circuits . if your basic be correct then you won't have any problem .
OK. Thanks. I am reading them, its really interesting.
@goldsmith
Many of theory in your given stuff I have studied before so I have understood it mostly.
At 50W power. Vopp=56V.
Is that were you asking for and you want I should understand.
Right to the point ! congratulations !
So , the out put voltage should be around 28 or approximately 30 volts !
so AV= vo /vin ---------> 30/2 = 15 ( but in practice you'd better to select it , around 18 ) .
Ok ?
OK :) Thanks.
OK sir. Now should we move further?
But don't forget that your op amp has not +-30 volts , as supply ! so i suggest you to amplify your in put around 12 volts and then add another section to amplify it nearby 30 volts , so can you find a way for 2nd section ? it is simple , think about it , but if you couldn't , of course i'll guide you more .
Best Wishes
Goldsmith
