The first thing you have to do is to check whether or
not your wiggler works well.
Check the circuit and pcb carefully.Maybe the problem just results from a wrong used risistor.
Then pull the inputs of 74HC244 to Vcc and Gnd and measure the outputs with a voltmeter to see whether they gives the correct response.
Then,if the problem still exists,see the settings of the software(LPT address,target setting,etc.).
Good luck!
