Javert
Member level 2
I am working on a PCB for a module with 2 to 4 pcs of 19 bit converters for thermocouples MAX31856.
The module will be connected to the processor with an approx. 30 cm cable.
The cheapest and easiest way is to power the entire module from a 3.3V LDO that powers the MCU.
On the module, several SMD C and possibly also SMD induction for noise shielding
On the other hand, I believe that a 19-bit ADC and an amplifier for thermocouples is a hell of a sensitive thing and a better solution is to supply the module with +5.0V and put your own low-noise LDO at 3.3V on the module.
Can anyone guess whether it makes sense to place a separate LDO on the board with the converters?
Thanks
Thanks
