why cannot I increase duty - single phase square wave inverter ?
anotherbrick
Full Member level 4
Istanbul , Turkey
hello dear forum,
I build a single phase - square wave - full bridge inverter for the output frequencies of 25 - 105 Hz
I drive the mosfets with IR2183S driver IC
the circuit here
my problem
I loaded the circuit with 500 W 220 V lamps
for higher output frequencies I can adjust duty between 10 - 70 % with the software - so far good
however if I decrease the output frequency below about 30 Hz the duty of the output square wave doesnot exceed %30 even if I adjust with the duty potentiometer
this is for lamp loaded condition
for no load , I can adjust and see duty of output at the osciloscope between 10 - 70 % - no problem
I observed the HIN-/LIN signal to IR2183 and LO gate signal to mosfet, no problem either ( while lamp loaded ) - goes down to 10 % and up to %70
however HO output has the same error : it doesnot goes above %30 duty
why is this strange behaviour ?
how can you help me
thank you
here Hgate vs HIN-/LIN
here Hgate vs Lgate
hello thank you Frank,
I suspect the same thing
this circuit is a square wave full bridge single phase inverter for changing line frequency to 25 - 105 Hz output
there is a 900 nF SMD cap as bootstrap capacitor
can I add a 1 uF electrolytic cap parallel to it ?
is there a danger of increasing the bootstrap capacitor ?
Not sure how you calculate duty cycle, but in my view a ssquare wave inverter would implement 50 % duty cycle (or may 49% to allow some dead time) and can hardly go above 50 %.
There's surely no bootstrap problem with 50 % duty cycle, so most likely you are talking about problem of your "pwm" controller circuit. Unfortunately you didn't even mention the controller type.
the controller is STM32
I calculate the duty as follows
I measuse the square wave length of half period * multiply with 2 / divide by the period length
the schematic is here
is there a problem if I increase the bootstrap capacitor ? what about an electrolytic cap ?
thank you
