anotherbrick
Full Member level 4
- Joined
- Jan 10, 2009
- Messages
- 214
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,298
- Location
- Istanbul , Turkey
- Activity points
- 3,114
hello dear forum,
I build a single phase - square wave - full bridge inverter for the output frequencies of 25 - 105 Hz
I drive the mosfets with IR2183S driver IC
the circuit here
my problem
I loaded the circuit with 500 W 220 V lamps
for higher output frequencies I can adjust duty between 10 - 70 % with the software - so far good
however if I decrease the output frequency below about 30 Hz the duty of the output square wave doesnot exceed %30 even if I adjust with the duty potentiometer
this is for lamp loaded condition
for no load , I can adjust and see duty of output at the osciloscope between 10 - 70 % - no problem
I observed the HIN-/LIN signal to IR2183 and LO gate signal to mosfet, no problem either ( while lamp loaded ) - goes down to 10 % and up to %70
however HO output has the same error : it doesnot goes above %30 duty
why is this strange behaviour ?
how can you help me
thank you
here Hgate vs HIN-/LIN
here Hgate vs Lgate
the circuit here
my problem
how can you help me
thank you
here Hgate vs Lgate
