What step to run Prime Time?
GoodMan
Full Member level 2
Hi all,
Can someone tell me about STA step?
What step to run Prime Time for STA? synthesis or layout
3Q
wadaye
Full Member level 4
Hi GoodMan,
You can run STA after Synthesis or layout. It's depend on your company's flow.
cdncrk
Junior Member level 2
GoodMan said:
Hi all,
3Q
there is a prime time tutorial in SOLD
eda_wiz
Advanced Member level 2
Two types of STA..
pre layout STA --after synthesis
post layout STA ==after layout..
its not just a single step.. lots of iterations are involved to fix all problems
aegean.chou
Member level 3
China
Read design
Set environment
Set constrain
Report timing
honeyxyb
Member level 2
book " Advanced Asic Chip Synthesis " show a normal sta flow about pre/pos layout. You can download from Edaboard.
horzonbluz
Full Member level 4
1. Set your PrimeTime env
2. Set your library
3. Read your design and link it to your tech library.
4. Read your clock and constraints.
5. Run PrimeTime to checkand report your paths in your design.
haosg
when you run post-apr sta, remember you need remove clock uncertainty and latency, and set propagated clock.
and you should set min library for max / min analysis.
spauls
Better go through Prime TIme manual, rather than going thru books
kelvin_sg
Singapore
The flow I did was as follows,
...Set library
...Set working environment
...Read in netlist
...Souce constraint file
...Annotate SDF file, either from P&R or design compiler
...Report timing and violations
...Done
HTH
Kelvin
AlexWan
Full Member level 5
<Advance Chip Synthesis>2nd
I think it is a good guide.
h**p://
ken_ooi
Member level 1
For post-route STA, you might need to read in the SPEF also.
allanweee
Junior Member level 1
I use PT for whole chip timing report even in presim or postsim.
sxqzj
Member level 4
Does it needs STA prelayout ?maybe it's a optional ,but i think it's not useful !
satya
Member level 3
bangalore
How Prime Time does the prelayout STA. Can anybody point me too some good appnote for Static Timing Analysis.
Thanks
Satya
rakko
Full Member level 4
mozambic
If you have access to synopsys solvenet web site. search for STA. they have lots of example scripts and app notes on their web site.
armmips
Member level 1
It is very useful. Thanks for your sharing.
wakki1187
Newbie level 5
do we need to generate .sdf file for a combinational circuit to check the path delay?
