what is "metastable-hard" Flip-Flops
yuenkit
"Instantiate double-clocking, metastable-hard Flip-Flops"
what does "metastable-hard" means?
Flipflops with low setup/hold requirements and fast metastable recovery.
    yuenkit
when setup/hold time violation is appered at that time the output of flipflop does not be stable means either 1 or 0
It could enduce setup/hold time violation, output should be dedicate value, never unknown
In a normal flop, when the input setup holds are violated, the output of flop will oscillates and eventually snaps to either one or zero. This snap time is usually a few times greater than your setup time. To model this behavior, the libraries usually set the outputs to X to indicates uncertainty.
In a meta-hard flop, as eda-wiz said, the flop is designed to tolerate more setup/hold violations and the library models usually don't do setup/hold checks on these flops. some people even design these flops not to oscilate but to hold their previous values in case of metastability.
Metastabilit is a common problem whn you do not respect setup time od a Flip-Flop. So, a metastable-hard flip-flop does not propagate errors when it happens. This means the output of the flip-flop is unknown, but stable (0 or 1) in a few time.
