biju4u90
Full Member level 3
While synthesizing a design in RTL Compiler, I reported the timing using report timing -lint command.
I got a warning message as follows:
Inputs without clocked external delays
The following primary inputs have no clocked external delays. As a result the
timing paths leading from the ports have no timing constraints derived from
clock waveforms. The'external_delay' command is used to create new external
delays.
/designs/minsoc_top/ports_in/jtag_tdi
/designs/minsoc_top/ports_in/jtag_tms
/designs/minsoc_top/ports_in/reset
I had specified input and external delays using set_input_delay and set_output_delay commands. Why I am getting this warning message?? What is "clocked external delays"?
delays.
