What is a good core utilization percent ?
liujingshu
Junior Member level 1
Core utilization
Hi, guy
My chip's core utilization only 81%. Does it meaning very bad?
Re: Core utilization
hi ..
i dont think your design is bad.
i have seen many designs with utilisation b/w 50-65% also.how come your's is bad
pandit
Core utilization
when u do inplace optimization and clock tree sythesis . core utilization will increase by buffer placement.
also u can have advantage if u have free space interms thermal effect.
but u have pay price for it
liujingshu said:
Hi, guy
81% utilization is pretty high...
pretty good design, of course you should address die size, if die size is small ,the utilization should be high.
Core utilization
normaly, if you have some bus,the utilization should be acceptable!!
Core utilization
81% is very good, I think. However, you may improve it if you can.
Core utilization
Hey Guys,
Can you suggest what is the maximum limit is to Total utilisation.
I mean which design one prefers a Standard design having 85% utilisation or a design having 95% utilisation.
Thanks uin advance
Core utilization
not bad i think.
Core utilization
It is recommended that the utilization be 75% for a good routing.
Added after 6 minutes:
However, you could do it as the case may be. If you have less interconnect, the utilization should be larger, vice versa. I think you could achieve an appropriate utilization after a few times of repeat.
