alexyangfox
Newbie level 6
- Joined
- Dec 2, 2010
- Messages
- 12
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,283
- Location
- Chengdu,sichuan,China
- Activity points
- 1,417
Dear, all.
I don't quite understand what "Saturation" means for a BJT and a MOSFET.
So I Searched on the internet and wikipedia says,
"Saturated transistor, a BJT transistor or field-effect transistor that is fully turned on."
So I suppose that a fully turned ON transistor is saturated.
But then I met the problem below:
1.
let me say,it's an npn bjt.when the term,"turned on" ,is used , I think this means I should treat the npn bjt as a switch,and the switch is connected into a circuit .For the circuit ,it's a two-terminal device,and its two terminals are emitter and collector. At the same time ,the base terminal is a control terminal.
If the transistor is fully turned on , the resistor across the two terminals, the collector and the emitter , must be very small.
And in the Amplification region the resistor is very big , because the Curve is almost a horizontal line. ΔIc/ΔVbe is almost zero,and the reciprocal ,the resistor, is very big.
And in the left region, the Saturation Region,the Resistor is very small , and the term "Saturation Region"seems reasonable...
But for the NMOS case, I am so puzzled.
2. NMOS.
I treat the NMOS as a two terminal device in a circuit two.
The two terminals are the drain and the source.
And also the gate is for controlling the switch's operation.
When this Nmos is fully turned on , I suppose the resistor across the two terminals is very small too.
But when looking at the I-V curve, the region with the biggest resistors is called "Saturation Region."
I'm so puzzled..
Could anyone here help me with this problem...
Thanks in advance.
Regards.
Alex.
1.
2. NMOS.
I'm so puzzled..
Thanks in advance.
Regards.
Alex.
