what do pipeline AD use for delay element
iexplorer
Member level 3
I have seen so many types ,like use C2MOS,dff,I try c2mos , however, when output is low , it can not hold for the full hold clock to make the ouput wrong,how can I deal with it ? Only edge DFF can give me exactly correct code?
Sample and hold is being used as delay element.... the MOS take care that the leakage current is too low.... you have bottom plate sampling and bootstrapping techniques.....
Hi
If do you mean digital signal answer is DFF
if analog signals answer is S/H.
regards
Hi DFF not necessary. Use a simple latch (two inverters + two switches as given in every digital design book) . Remember using non overlapping clocks for different latches.
