What causes WARNING:Xst:2677 in a VHDL code?
Twix25
Newbie level 3
montreal
Hello,
I have got a warning in implementation of my vhdl code but I didn't find the problem cause
warning msg:
WARNING:Xst:2677 - Node <map28/out_del_3> of sequential type is unconnected in block <top>.
WARNING:Xst:2677 - Node <map28/out_del_2> of sequential type is unconnected in block <top>.
WARNING:Xst:2677 - Node <map28/s_delay_3> of sequential type is unconnected in block <top>.
delay code
entity Delay is
    Port ( clk : in  STD_LOGIC;
	        reset: in STD_LOGIC;
           in_del : in  STD_LOGIC_VECTOR (31 downto 0);
           out_del : out  STD_LOGIC_VECTOR (31 downto 0));
end Delay;
architecture Behavioral of Delay is
signal s_delay: STD_LOGIC_VECTOR (31 downto 0);
begin
process (clk)
  begin
   if clk='1' and clk'event  then
		 if reset='0'  then
    	   out_del <= s_delay;
   		s_delay <= in_del;
        else
		   out_del <= "00000000000000000000000000000000";
		 end if;
  end if;
 end process;
end Behavioral;
xst:2677
I guess one of ur instantiation output is not properly mapped.
Thks for reply.
I check the mapping and all seems correct: Here is an extract from my mapping code top level:
signal s0: STD_LOGIC_VECTOR (31 downto 0):= (others => '0');    signal s1: STD_LOGIC_VECTOR (31 downto 0):= (others => '0');
signal s2: STD_LOGIC_VECTOR (31 downto 0):= (others => '0');    signal s3: STD_LOGIC_VECTOR (31 downto 0):= (others => '0');
signal s50: STD_LOGIC_VECTOR (31 downto 0):= (others => '0');   signal s51: STD_LOGIC_VECTOR (31 downto 0):= (others => '0');
signal s52: STD_LOGIC_VECTOR (31 downto 0):= (others => '0');   signal s53: STD_LOGIC_VECTOR (31 downto 0);
map20: Delay port map(clk,reset,s12,s20);
map21: R_shifter port map(s20,s21);
map22: Adder port map(s12,s21,s22);
map23: L_shifter port map(s34,s23);
map24:  Adder port map(s19,s23,s24);
map25: Delay port map(clk,reset,s52,s25);
map26: Delay port map(clk,reset,s25,s26);
map27: Delay port map(clk,reset,s26,s27);
map28: Delay port map(clk,reset,s27,s28);
map29: R_shifter port map(s28,s29);
All problems is comming with the delay sub bloc.
It seems to be proper only...
usually this warning will occur only when the signals bits are not used..
it seems that s_delay_3, out_del_2 & out_del_3 are not used in the design...
whether the signals are taken out from the top module?
if the functionality of ur design works fine in gate level simulation u can ignore these warnings.
