h_cet
Member level 4
hi
I have two questions
1) I want to finish with 50 ohm from behind microstrip antenna. How Can I finish the end of the mikrostrip antenna? I use lump port for finishing the end of the microstrip antenna. Is it true? I know that the lump port is a passive. Is ıt true?
2) I define the air bigger than antenna structure. Does air which is drawn for different lenghts on same structure lenghts change result?
thanks for your helps
