Virtuoso IC6.16 - DC simulation - Annotate DC OP failed
Chr's
Junior Member level 1
Hi everyone,
My issue is about a DC simulation.
When this one is finished, and I wanted annotate the DC operating points on the schematic, They are not displayed for all components.
For example, I've 2 dc sources, but the DC operating point is displayed only for one of them. I save all the points (Output -> Save all -> check boxes on "all").
If someone has the solution, thanks in advance.
Regards,
Hi
Sometimes Cadence is a little bit tricky at some point when using save all :).
Could you make sure that you save individually the nets you are interested in (outputs>to be saved>select on shcematic)?
Hi
It's big schematic and I cannot select all the points, that's why select: save point "all"with a check box
