abhijeet.kumar
Newbie level 5
Dear sir
This is my code for providing motion to a robo on a uniform plane .designed using three points.I have only two errors please help me & rectify my errors.Errors & coding are given below.
ERRORS
ERROR:HDLCompiler:1638 - "C:\Users\dell\Desktop\vhdl\RFID2\iseconfig\HANMAN2\ROBO.vhd" Line 119: found '0' definitions of operator "=", cannot determine exact overloaded matching definition for "="
ERROR:HDLCompiler:854 - "C:\Users\dell\Desktop\vhdl\RFID2\iseconfig\HANMAN2\ROBO.vhd" Line 60: Unit <behavioral> ignored due to previous errors.
VHDL CODE
ERRORS
VHDL CODE
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 library IEEE; use IEEE.STD_LOGIC_1164.ALL; package controler is constant rng_row : integer:= 2; constant rng_clmn : integer:= 2; constant gps_row : integer:= 2; constant gps_clmn,lut_clmn: integer:= 2; constant lut_row : integer:=7; Type lut_datain is array (0 to lut_row,0 to lut_clmn)of std_logic; signal temp3:lut_datain; Type gps_datain is array (0 to gps_row,0 to gps_clmn) of std_logic; Type rng_datain is array (0 to gps_row,0 to gps_clmn) of std_logic; -----Type rng_datain is array (0 to rng_row,0 to rng_clmn )of std_logic; -----signal temp5:gps_datain; ---array (0 to rng_row, 0 to rng_clmn); end controler; library IEEE; use IEEE.STD_LOGIC_1164.ALL; use WORK.controler.ALL; entity ROBO is port (clk: in std_logic; x1,x2,x3,x4,x5,y1,y2,y3,z1,z2,z3: inout std_logic; df_in1,df_in2:in gps_datain; df_in3:in lut_datain; -- in array (0 to rng_row,0 to rng_clmn); df_out1,df_out2:inout gps_datain; df_out3: out lut_datain; mc_in1: in gps_datain; mc_in2: in rng_datain; mc_out1: inout gps_datain; mc_out2: inout rng_datain; mcomp_out,dcomp_out:out std_logic); end ROBO; architecture Behavioral of ROBO is --Type gps_datain is array (0 to gps_row,0 to gps_clmn) of std_logic; signal temp1,temp2: gps_datain ; signal temp5:gps_datain; variable gps_data:gps_datain:= ((x1, y1, z1), (x2, y2, z2), (x3, y3, z3)); --------Type rng_datain is array (0 to rng_raw,0 to rng_clmn )of std_logic; signal temp4:rng_datain; variable rng_data:rng_datain:= ((x1, y1, z1), (x2, y2, z2), (x3, y3, z3)); SIGNAL i : integer := 0; begin -----------------------------------------for direction finder---------------------------------------------------- p1:process(clk) type lut_datain is array (0 to lut_row,0 to lut_clmn)of std_logic; constant lut_data:lut_datain:=( ('0','0','0'), ('0','0','1'), ('0','1','0'), ('0','1','1'), ('1','0','0'), ('1','0','1'), ('1','1','0'), ('1','1','1')); begin if ( clk = '1' and clk'event)then for i in 0 to 5 loop case i is when 0 => temp1<= df_in1; when 1 => df_out1<= temp1; when 2 => temp2<= df_in2; when 3 => df_out2 <= temp2; when 4 => temp3 <= df_in3; when 5 => df_out3<= temp3; end case; end loop; if (df_out1 = df_out2 and df_out1 = df_out2) then dcomp_out <= '1'; else dcomp_out <= '0'; end if; end if; end process; --------------------------for motion control---------------------------------------------- p2:process(clk) begin if (clk'event and clk = '1')then for i in 0 to 3 loop case i is when 0 => temp5 <= mc_in1; when 1 => mc_out1 <= temp5; when 2 => temp4 <= mc_in2; when 3 => mc_out2 <= temp4; end case; if (mc_out1 = mc_out2) then mcomp_out <= '1'; else mcomp_out <= '0'; end if; end loop; end if; end process; end Behavioral;
