8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
| library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
package controler is
constant rng_row : integer:= 2;
constant rng_clmn : integer:= 2;
constant gps_row : integer:= 2;
constant gps_clmn,lut_clmn: integer:= 2;
constant lut_row : integer:=7;
Type lut_datain is array (0 to lut_row,0 to lut_clmn)of std_logic;
signal temp3:lut_datain;
Type gps_datain is array (0 to gps_row,0 to gps_clmn) of std_logic;
Type rng_datain is array (0 to gps_row,0 to gps_clmn) of std_logic;
-----Type rng_datain is array (0 to rng_row,0 to rng_clmn )of std_logic;
-----signal temp5:gps_datain; ---array (0 to rng_row, 0 to rng_clmn);
end controler;
library IEEE;
use WORK.controler.ALL;
entity ROBO is
port (clk: in std_logic;
x1,x2,x3,x4,x5,y1,y2,y3,z1,z2,z3: inout std_logic;
df_in1,df_in2:in gps_datain;
df_in3:in lut_datain; -- in array (0 to rng_row,0 to rng_clmn);
df_out1,df_out2:inout gps_datain;
df_out3: out lut_datain;
mc_in1: in gps_datain;
mc_in2: in rng_datain;
mc_out1: inout gps_datain;
mc_out2: inout rng_datain;
mcomp_out,dcomp_out:out std_logic);
end ROBO;
architecture Behavioral of ROBO is
--Type gps_datain is array (0 to gps_row,0 to gps_clmn) of std_logic;
signal temp1,temp2: gps_datain ;
variable gps_data:gps_datain:=
((x1, y1, z1),
(x2, y2, z2),
(x3, y3, z3));
--------Type rng_datain is array (0 to rng_raw,0 to rng_clmn )of std_logic;
signal temp4:rng_datain;
variable rng_data:rng_datain:=
((x1, y1, z1),
(x2, y2, z2),
(x3, y3, z3));
SIGNAL i : integer := 0;
begin
-----------------------------------------for direction finder----------------------------------------------------
p1:process(clk)
type lut_datain is array (0 to lut_row,0 to lut_clmn)of std_logic;
constant lut_data:lut_datain:=(
('0','0','0'),
('0','0','1'),
('0','1','0'),
('0','1','1'),
('1','0','0'),
('1','0','1'),
('1','1','0'),
('1','1','1'));
begin
if ( clk = '1' and clk'event)then
for i in 0 to 5 loop
case i is
when 0 => temp1<= df_in1;
when 1 => df_out1<= temp1;
when 2 => temp2<= df_in2;
when 3 => df_out2 <= temp2;
when 4 => temp3 <= df_in3;
when 5 => df_out3<= temp3;
end case;
end loop;
if (df_out1 = df_out2 and df_out1 = df_out2) then
dcomp_out <= '1';
else
dcomp_out <= '0';
end if;
end if;
end process;
--------------------------for motion control----------------------------------------------
p2:process(clk)
begin
if (clk'event and clk = '1')then
for i in 0 to 3 loop
case i is
when 0 => temp5 <= mc_in1;
when 1 => mc_out1 <= temp5;
when 2 => temp4 <= mc_in2;
when 3 => mc_out2 <= temp4;
end case;
if (mc_out1 = mc_out2) then
mcomp_out <= '1';
else
mcomp_out <= '0';
end if;
end loop;
end if;
end process;
end Behavioral; |
