[SOLVED] vhdl code for cypher....i am having the problem in this code ...can anyone help me?
chandrapal1990
Junior Member level 3
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
---- my libraries declarations ----
library CIPHER;
entity geffe is
port(
Clk :in std_logic_vector;
Rst :in std_logic;
Keystream :eek:ut std_logic
end geffe;
library IEEE;
library CIPHER;
architecture geffe_structure of geffe is
---- Component declarations -----
component lfsr_13
generic(N : integer := 13);
port (
clk :in std_logic;
reset :in std_logic;
lfsr_out :eek:ut std_logic
end component;
component lfsr_5
generic(N : integer := 5);
port (
clk :in std_logic;
end component;
component lfsr_8
generic(N : integer := 8);
port (
clk :in std_logic;
end component;
component mux2_1
port (
inA :in std_logic;
inB :in std_logic;
selectline :in std_logic;
output :eek:ut std_logic
end component;
---- Signal declarations used on the schematic diagram ----
signal x1 :std_logic;
signal x2 :std_logic;
signal x3 :std_logic;
--signal clk :std_logic;
--signal Rst :std_logic;
--signal Keystream: std_logic;
begin
---- Component instantiations ----
LFSR_1 : lfsr_13
port map(
clk => clk,
lfsr_out => x1,
reset => Rst
LFSR_2 : lfsr_8
port map(
clk => Clk,
lfsr_out => x2,
reset => Rst
LFSR_3 : lfsr_5
port map(
clk => Clk,
lfsr_out => x3,
reset => Rst
Mux21 : mux2_1
port map(
inA => x1,
inB => x3,
output => Keystream,
selectline => x2
end geffe_structure;
then you need to create the cypher library in the tool you're using- but given you dont use anything from it - you dont need it.
