Hafeez Ur Rehman
Newbie level 3
I am facing a problem in my LCD interface code..
Is there any other reason for not getting data on 2nd line of LCD!!!???
Hoping for the help and guidance....
here is my lcd_mod module
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 module lcd_mod ( input CLK_50MHZ, output LCD_E, output LCD_RS, output LCD_RW, output [3:0] LCD_D, // input [31:0] if_data, input if_write, output if_ready ); reg [127:0] if_data=128'h56539856123455221234567812345678; // always @ (posedge clk) reg [7:0] disp_data; reg disp_rs; reg [31:0] disp_delay; reg disp_write; wire disp_ready; reg disp_b8; reg [7:0] char; reg [1:0] state; reg [127:0] number; reg init_done; reg running; reg [5:0] shift_cntr; reg if_ready_r; assign if_ready = if_ready_r; lcd_display display (.clk(CLK_50MHZ), .rst(1'b0), .lcd_e(LCD_E), .lcd_rw(LCD_RW), .lcd_rs(LCD_RS), .lcd_d(LCD_D), .if_data(disp_data), // hafeez? .if_rs(disp_rs), .if_delay(disp_delay), .if_write(disp_write), .if_ready(disp_ready), .if_8bit(disp_b8) ); parameter NB_CHARS = 8'd12; parameter START = 2'b00, WAIT_WRITE_0 = 2'b01, WRITE_1 = 2'b10, WAIT_WRITE_1 = 2'b11; initial begin state <= 2'b00; char <= 8'b0; init_done <= 1'b0; if_ready_r <= 1'b0; shift_cntr <= 5'b0; end always@ (posedge CLK_50MHZ) begin if (init_done && char > 8'd26) begin//najam if (disp_ready) if_ready_r <= 1'b1; if (if_write) begin char <= 4'd8; // reset the display end end else if (char <= 8'd26) begin//najam if_ready_r <= 1'b0; case (state) START: if (disp_ready) begin disp_write <= 1'b1; state <= WAIT_WRITE_0; end WAIT_WRITE_0: state <= WRITE_1; WRITE_1: begin disp_write <= 1'b0; state <= 2'b11; end WAIT_WRITE_1: begin state <= START; char <= char + 8'b1; end endcase // case (state) end // else: !if(!running) end // always@ (posedge CLK_50MHZ) always@ (negedge CLK_50MHZ) begin // these next steps initialize the LCD display: case (char) 0: begin disp_b8 <= 1'b0; disp_data <= 8'h30; disp_delay <= 32'd10000000; disp_rs <= 1'b0; end 1: disp_data <= 8'h30; 2: begin disp_data <= 8'h30; disp_delay <= 32'd1000000; end 3: begin disp_data <= 8'h20; disp_delay <= 32'd20000; end 4: begin disp_b8 <= 1'b1; disp_data <= 8'h28; end 5: disp_data <= 8'h06; 6: disp_data <= 8'h0C; 7: begin disp_data <= 8'h01; disp_delay <= 32'd1000000; init_done <= 1'b1; shift_cntr <= 5'd32;//najam end 8: // this state provides an entry point to reset the display and then // go on to the default state that writes the number begin disp_rs <= 1'b0; disp_data <= 8'h01; disp_delay <= 32'd1000000; shift_cntr <= 5'b0; number <= if_data; end default: // state machine to print a 32-bit number out if (disp_ready && state == START) begin if (shift_cntr < 5'd31) begin//najam disp_rs <= 1'b1; disp_delay <= 32'd10000; if (number[127:124] < 4'b1010) disp_data <= number[127:124] + 8'h30; else disp_data <= number[127:124] + 8'h37; number <= number << 4; shift_cntr <= shift_cntr + 5'b1; //disp_data<= 8'h48; end end endcase // case (char) end // always@ (negedge CLK_50MHZ) endmodule
