[SOLVED] Please help for Data transferring between Verilog Modules
EDA_hg81
Advanced Member level 2
Any helps for the following Verilog coding are appreciated.
Pulsewidth module is instantiated in top_pll module and the data port will be transferred from pulsewidth module to top_pll module for further processing.
I have defined the data port in pulsewidth module with r_count_hi (define as reg) and r_count_hi is assigned to output port by assign o_pulse_len_hi = r_count_hi;
The pulsewidth module can work alone very well as shown in the attached simulation image.
But when combine pulsewidth module with top_pll module, the data port can not be transferred to top_pll module properly as shown in the attached image, I have defined the data input port of top_pll module as wire.
If it is possible, please let me know any problems for above problem.
Many thanks in advance.
--- Updated ---
I have found the root cause for this problem.
I should not initialized wire[7:0] up_width_counta = 8'b00;
Only need to define as wire[7:0] up_width_counta; will solve the problem.
