Verilog RTL and Behavioral Testbench
davyzhu
Advanced Member level 1
oriental
Hi all,
I am reading the book "Writing Testbench" and found my previous testbench style is RTL.
Can I change Verilog RTL Testbench to Behavioral Testbench, is the below code right?
//---- RTL style---
Always@(posedge clk)
If(EN)
//----Behavioral style---
Always begin
wait(EN);
@(posedge clk);
end
Is there any other better Behavioral style?
Any suggestions will be appreciated!
Best regards,
Davy
muhammad kashif
Newbie level 1
this is the write way to right programe in behavioral level
Thomson
Full Member level 3
In fact, these two different descriptions are not the same if the comprehension on the meaning of wait (signal_a) especially if this statement is used in post-layout simulation.
To be the same, the sampled under the rising edge of the clock shall be used as follow:
wait (signal_a_sampled);
Best Regards,
Thomson
davyzhu
oriental
I see.
When EN in not valid @(posedge clk), the behavioral model will be wrong. How to write a full right model?
Best regards,
Davy
woodyplum
Member level 2
two total different descrition, only the same if you are waiting for the occur(one time event) of the En, in this status the later one should be more efficient
JesseKing
agree with thomson.
and I want to know why you want to convert your rtl to behavioral level
archillios
Full Member level 1
i dont think verilog is a good behavioral modeling language. it's short of high-level description capability. using verilog to write rtl model is more comfort, if you want high-level modeling, turn to system verilog or system c.
