verilog program of reconfigurable johnson counter
jincyjohnson
Member level 4
can you give me the verilog code of reconfigurable johnson counter.ie; there are two external inputs-mode and init.when mode=0,it works as a johnson counter.when mde=1 & init=0, it should reset. when mode=1 & init=1,it works as a ring counter.actually i initialize all the flip flops output first.but only johnson counter and reset works, ring counter doen't work.in ring counter mode the output is all zeros .can u give me the verlog code
How about you put in some time and try it first. When you're stuck show your code + explain where you are stuck.
here i attach code and block diagram.in ring counter mode, output are zeros
  • johnson cntr.pdf
  • johnson counter.pdf
Okay, that's a good start. Do you have a testbench + testbench results to go with that? Oh and it's probably easier if you post the code using [code] tags (instead of attaching a pdf with verilog code in it). Also see this one for a quick description:
Code Verilog - [expand]
[syntax=verilog]
[/syntax]
module johnson(clk,rst,init,rjmode,q);
input clk,rst,rjmode,init;
parameter n=5;
output [n-1:0]q;
reg [n-1:0]q_i;
reg temp;
integer I;
always @(posedge clk or negedge rst)
begin
if(!rst)
for(I=0; I<=n-1; I=I+1)
q_i <= 1'b0;
else
begin
if (!rjmode)
temp = ~q_i[n-1];
else
temp = (q_i[n-1]) &&(init);
for(I=n-1;I>=1; I=I-1)
begin
q_i[I] = q_i[I-1];
end
q_i[0] = temp;
end
end
assign q = q_i;
endmodule
  • New Microsoft Office Word Document.doc
can you give me the test bench code for the program.how can we write test bench for a program with 'for loop'
