jincyjohnson
Member level 4
can you give me the verilog code of reconfigurable johnson counter.ie; there are two external inputs-mode and init.when mode=0,it works as a johnson counter.when mde=1 & init=0, it should reset. when mode=1 & init=1,it works as a ring counter.actually i initialize all the flip flops output first.but only johnson counter and reset works, ring counter doen't work.in ring counter mode the output is all zeros .can u give me the verlog code
