VCS Errors (Undefined system task) $recordfile & $record
omara007
Cairo/Egypt
undefined system task call to $vcdpluson
Hi folks
I'm trying to compile my files on VCS, and I'm getting these 2 errors:
Error-[UST] Undefined system task
Undefined System Task call to '$recordfile'
/path_to_my_file/my_file.v
", 214
Undefined System Task call to '$recordvars'
", 215
What should I do to avoid these errors ?
vcs debug_pp
According to those Error messages, 2 system tasks $recordfile and $recordvars are undefined.
Please define these 2 system tasks in Verilog then the problem will be solved.
vcs tasks
The 2 mentioned system tasks { $recordfile and $recordvars } are already supported by synopsys. Please read this link :
https://solvnet.synopsys.com/dow_retrieve/A-2007.12/espcv/espcv_5.html#CACJECDH
They exist under SST2 Dump File Support :
$recordfile
$recordvars
system call vcdpluson
Live And Learn
According to the above link, these 2 system tasks are supported in product ESP.
Do they also supported in VCS ?
Thanks in advance.
vcs+errors
joe2moon said:
Live And Learn
Thanks in advance.
$recordvars is part of Signalscan which was a separate tool, now part of Cadence. You need to set the correct TAB file for the same. WHy don't you just use the VPD format that's native in VCS? Much easier to use:
initial
 $vcdpluson;
vcs -debug_pp file.v
HTH
Ajeetha, CVC
www.noveldv.com
vcs undefined system call
In fact, I'm verifying an external IP using the IP's supplier own testbenches/scripts .. these testbenches/scripts were originally written for use with ModelSim .. currently I want to port the whole simulation environment to VCS as it's my company's default simulator ..
How can I use the proper TAB file ?
undefined system task fsdbdumpfile
Please use the "-P" option to specify the necessary tab file as following:
> vcs -P <filename.tab>
vcs error ust undefined system call
OK .. but what tab file is the one needed ??
hi,who could end this question?
I meat a simular question
when I use the vcs to produce the vcd+ file,it came out that
the systerm task is not define
