Dear all,
I need a signal near 100MHz,the general method is to design with PLL.But, my requirement of frequency stability is not strict,20ppm or 50ppm is accepted,also my requirement of PCB size is strict.
1)my first choice is to find a fully integrated IC including PLL and VCO, and N/R divider is also in-chip,so that the output signal will be ok once VCC is connected correctly.
Would you please kindly advise some part like that for me? thank you!
2)My second choice is to use oscillator directly,such as TCXO which has 4 pins(VCC/GND/EN/OUTPUT) .It's not a standard or perfect design, but i'll use it when my first choice could not be reached.
Oscillator output is squarewave and need to be filtered enough for harmonics rejection. or, is there anything i should consider? thanks.
My operation frequency is in 80~120MHz and only one frequency point is ok, thanks a lot!
