Output is asserted 1 if
pattern 101 is detected in last 4 inputs.
Eg: I/P 0 1 0 1 0 0 1 1 0 1 0 1 0
O/P 0 0 0 1 1 0 0 0 0 1 1 1 1
i am done with the state diagram(7 states ) n using D-Flip Flops...but for giving the inputs to the DFF's i got 3 equations ..as i hav to use min harware i am planning to implement the equations using PLA(programmable logic array) r PAL...but i hav to write verilog code for the above design n test it....
WILL IT BE POSSIBLE TO WRITE VERILOG CODE FOR THE PLA R PAL I USE r is there any other way i can reduce the hardware (for the input equations of DFF's)
plzz respond its very urgent
thnx in advance
