Urgent: Frequency division
olajide85
Newbie level 5
Nigeria
I have been having issue on testing this code on the altera board. ths code is meant to convert 5oMHz to 1Hz. after testing it on the board, I discovered it is nopt working on the altera board. I need help on this. this is the code. I will appreciate your urgent response.
ENTITY FDIVIDER IS
-- {{ALTERA_IO_BEGIN}} DO NOT REMOVE THIS LINE!
PORT
clk : IN STD_LOGIC;
clkout : OUT STD_LOGIC
-- {{ALTERA_IO_END}} DO NOT REMOVE THIS LINE!
END FDIVIDER;
-- Architecture Body
ARCHITECTURE FDIVIDER_architecture OF FDIVIDER IS
BEGIN
PROCESS (clk)
VARIABLE count : INTEGER RANGE 0 TO 25000000;
BEGIN
if(clk'event and clk='1') then
if(count=25000000)then
count:=0;
clkout<='0';
else
count := count+1;
clkout<='1';
END IF;
END IF;
END PROCESS;
END FDIVIDER_architecture;
Reset and initialisation of clkout?
begin
   if reset = '1' then
      clkout <= '0';
   elsif rising_edge(clk) then
--etc
Also, be aware that clkout is only changing state for a very, very short time
olajide85, your code creates a very short low pulse (1/25000000 sec duration) and then returns to High again, is that what you want?
I think what you want is to make the output 1 after 25000000 clocks , then 0 after 25000000 more clocks , then 1 after 25000000 more clocks etc.
Alex
what I want is to convert 50MHz to 1Hz with the codes above so that i can test the design on the altera board....any modification to it?
---------- Post added at 19:46 ---------- Previous post was at 19:36 ----------
alexan_e, can you modify it for me?
Use a variable out_buf,
then when the count is 25000000 use out_buf:= not out_buf;
then just assign this value to the output clkout<= out_buf;
Alex
please am new to this.can you help me edit it on the code posted?
---------- Post added at 19:59 ---------- Previous post was at 19:54 ----------
50MHz to 1Hz using vhdl.
The point is for you to learn and I have already explained what you need to do , it is not that hard.
This code gives only a pulse because
count:=0;
clkout<='0'; -- this will be true only for one clock
else
count := count+1;
clkout<='1'; -- and then the value will return to this until you reach 25000000 again
You can do something simpler for you, when the count is 25000000 set clkout<='1';
and when count is 50000000 set clkout<='0';
i tried it but getting errors. Can you edit it on the one i posted in the forum.
Hi Olajide85,
I think this should work... See the code below....
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY FDIVIDER IS
PORT
clk : IN STD_LOGIC;
rst : IN STD_LOGIC;
END FDIVIDER;
begin
process (rst,clk)
variable count : integer range 0 to 49999999 := 0;
begin
if(rst = '1') then
count := 0;
clkout <= '0';
elsif(rising_edge(clk)) then
if(count < 25000000)then
count := count + 1;
clkout <= '0';
elsif(count >= 25000000 and count <= (49999999 - 1)) then
count := count + 1;
clkout <= '1';
elsif(count = 49999999) then
count := 0;
end if;
end if;
end process;
