Thanks for your response. Few clarifying questions:
1. Does clamp value only tell the tool to choose which kind of gate to use?
2. Let's say clamp value is 0, hence, I believe AND gate will be used as isolation cell. I guess when isolation signal is inactive (should be 1 in this case), this AND gate will act as a buffer, but when it is active (should be 0, same as clamp value), output of isolation cell will be 0. Is this correct?
3. How does isolation sense fits here? If #2 is correct, based on clamp value only we can decide if isolation signal can be high or low.
PS: I was not able to find a detailed circuit of an isolation cell, hence, I have these questions.
Thanks,
Abhishek
