I don't know what simulator you use since you don't mention anything about it but as fas as cadence is concerned you can estimate the desired product by yourself and ofcourse compare it to the value that erikl's link suggests for confirmation of correct calculations.So,after your dc analysis in cadence spectre go to Print Model Parameters choise from ADE L's top menus and find the parameter u0,this corresponds to the mobility.Cox can be calculated by the well known formula from the bibliography (the value of the tox parameter is written in your pdk's manual according to the type of devices you use-thin/thick oxide etc...).Hope the above helped you!
