Darktrax
Full Member level 5
Dishal's method is easily searched, and has been mentioned in this forum before. Essentially, by temporarily short-circuiting all but the first sections of a filter, and then tuning for maxima and nulls while sequentially removing the short-circuits, an exact proper tuning can be done quickly.
The method is very easily applied in simulation, but is also used by deliberately making devices with tuned circuits shorted out, the short being removed during adjustment by laser trimming, or simply cutting.
Direct hand-adjusting without this trick can give apparently near-correct passband results, even though it ends up using a combination of capacitor values that are very different from the ideal. Also, it takes much time, and there is a certain skill in recognizing which maxima and minima to adjust, and how they "tilt".
Current link--> Dishal's Method
What I seek is any detail on a variation of this method where during sweep testing, both the passband and the input reflection are displayed. The filter is connected via a quite long 50-Ohms high quality cable, and a section of "stretchable" line - a variable length coax of telescopic sliding tube. There is no need for direct intervention inside the filter with short (or open) circuits.
The sweep display would show multiple waves and nulls. The method involved setting a marker frequency, adjusting the coax length to bring a null onto the marker, then tuning the filter for some maximum (or minimum). Then the stretchable line would be altered to the next quarter-wave point, and another capacitor tuned. As the final capacitor is tuned, the passband comes up correct in a very striking impressive way.
I would be grateful if anyone has clearer details of this procedure, and how it works - many thanks if you can help.
