ling4ever
Junior Member level 1
- Joined
- Mar 25, 2012
- Messages
- 15
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Philippines
- Activity points
- 1,416
I am designing a 1.6mm thick 6-layer pcb to be used continous at high temperature (+125C) and will have one 15-Ampere supply (3.3V). This 15A will be distributed to the whole board with a two layer 1 oz copper plane (L3 and L4). However, the weakest link between the outside supply and the copper plane is thru-hole fuse connection. Do I really need to have spoke connection on the fuse leads? Four 25-mil spoke will not be enough to carry 15A.
I am thinking of providing copper connection on three layers from the pcb terminal (interface between the outside ower supply and the PCB) to one pin of the fuse. Namely, top, L3 and L4 will have a copper shape of about 1000 mils by 500 mils connecting the terminal to the fuse.
The three layer connection will provide about 300 mil spoke? Is this enough? Or is it better if I will not use spoke and will directly connect the thru-hole fuse pin to the shape?
Please also consider that my ambient temperature will be +125C during the board operation.
I included a snapshot of the top layer layout of the connection from the pcb terminal to one of the fuse pin.
