The low value of drop out voltage in LDO
greenhand
Newbie level 6
Hi , every one
In some LDO datasheet , It is said that the drop out voltage is below
several hundrends or decades mV . But I think under such low
Vds or Vce , the pass transistor has fall out linear active region ,
so lost the function of regulator . Is there some one can help me?
Re: Question about LDO
hallo greenhand,
the trick with very low dropout regulators is that a charge pump is used. This charge pump enables a gate voltage higher than vdd. So the pass transitors can be kept in linear region.
