The flow of primetime for bottom-up syn
tigerajs
Member level 3
Member level 3
run pt for each sub module or only run the top module use every SDC,thanks
If you see in other way around... bottom up approach for a chip means top down for that particular Block/core/submodule right. Thus need to close timing exclusively. Then try and extarct the timing models of the blocks and then perform full chip timing. This will save the run time also.
Cheers
