Tester for PIC16F877A
MiszEchah
I have to design a tester for PIC16F877A..I need a help coz I didnt get the idea yet..any idea to design this tester?
bigdogguru
Administrator
Southwest, USA
What aspects of the device are you required to test?
Are the tests environmental as well as operational?
BigDog
MiszEchah
I have to test whether the PIC16F877A is working or not. Before we used it we test it, it is okay or not.
Yes, the tests environmental as well as operational..
xxtigerxx
Advanced Member level 1
Greece
the test is for a specific program or you test the IC is good or not?
MiszEchah
just want to test the IC is good or not..that's all..can you give me a little bit idea..
xxtigerxx
Greece
to test the IC if it good.
you just need a programmer. To test if can be written.
And also you can wirte a simple program to check the I/O with leds.
MiszEchah
I still don't get it, so i just write a simple program then i run it?
bigdogguru
Administrator
Southwest, USA
To fully test the device operationally, you should test each peripheral module, ADC, USART, Timers, Comparators, etc.
A test "jig" board which can provide various analog and digital stimuli combined with test results transmitted through a serial connection to a monitoring PC is an option.
The devices program can be designed to manipulate the various stimuli inputs recording the results as the test progresses.
Environmental testing requires subjecting the device to both its stated temperature range and operational voltage range while running the above tests.
This is usually performed with a test "jig" board which can be mounted in an environmental chamber where temperature and humidity can be precisely controlled.
However, you'll most likely need to utilize a freezer and oven which provide adequate control over the temperature levels.
It all depends on how well you need to test the device and compare your findings to the devices datasheet.
BigDog
MiszEchah
Oic..Ok thanks for the details explanation. I'll get thru the experiment then I'll ask u again :)
