Thanks,but what do you mean about all of the files in the simulation and source directories of the IP?
it should be cordd.vhd cordd_tb.vhd and what else?
component cordic_sample_gener is
component altera_avalon_clock_source is
component altera_conduit_bfm is
component altera_conduit_bfm_0002 is
component altera_avalon_reset_source is
altera_avalon_clock_source.sv
altera_avalon_reset_source.sv
altera_conduit_bfm.sv
altera_conduit_bfm_0002.sv
cordic_sample_gener.vhd
cordic_sample_gener_nco_ii_0_tb.vhd
verbosity_pkg.sv
vlog -reportprogress 300 -work work {/home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/altera_avalon_clock_source.sv}
# Model Technology ModelSim ALTERA vlog 10.3d Compiler 2014.10 Oct 7 2014
# Start time: 13:55:09 on Apr 19,2016
# vlog -reportprogress 300 -work work /home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/altera_avalon_clock_source.sv
# -- Compiling module altera_avalon_clock_source
# ** Error: /home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/altera_avalon_clock_source.sv(30): (vlog-13006) Could not find the package (verbosity_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
# End time: 13:55:09 on Apr 19,2016, Elapsed time: 0:00:00
# Errors: 1, Warnings: 0
vlog -reportprogress 300 -work work {/home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/altera_avalon_reset_source.sv}
# vlog -reportprogress 300 -work work /home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/altera_avalon_reset_source.sv
# -- Compiling module altera_avalon_reset_source
# ** Error: /home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/altera_avalon_reset_source.sv(34): (vlog-13006) Could not find the package (verbosity_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
vlog -reportprogress 300 -work work {/home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/altera_conduit_bfm.sv}
# vlog -reportprogress 300 -work work /home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/altera_conduit_bfm.sv
# -- Compiling module altera_conduit_bfm
# ** Error: /home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/altera_conduit_bfm.sv(56): (vlog-13006) Could not find the package (verbosity_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
vlog -reportprogress 300 -work work {/home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/altera_conduit_bfm_0002.sv}
# vlog -reportprogress 300 -work work /home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/altera_conduit_bfm_0002.sv
# -- Compiling module altera_conduit_bfm_0002
# ** Error: /home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/altera_conduit_bfm_0002.sv(56): (vlog-13006) Could not find the package (verbosity_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
vlog -reportprogress 300 -work work {/home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/verbosity_pkg.sv}
# vlog -reportprogress 300 -work work /home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/verbosity_pkg.sv
# -- Compiling package verbosity_pkg
# Top level modules:
# --none--
# Errors: 0, Warnings: 0
vcom -reportprogress 300 -work work {/home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/cordic_sample_gener.vhd}
# Model Technology ModelSim ALTERA vcom 10.3d Compiler 2014.10 Oct 7 2014
# Start time: 13:55:10 on Apr 19,2016
# vcom -reportprogress 300 -work work /home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/cordic_sample_gener.vhd
# -- Loading package STANDARD
# -- Loading package TEXTIO
# -- Loading package std_logic_1164
# -- Loading package NUMERIC_STD
# -- Compiling entity cordic_sample_gener
# -- Compiling architecture rtl of cordic_sample_gener
# End time: 13:55:10 on Apr 19,2016, Elapsed time: 0:00:00
vcom -reportprogress 300 -work work {/home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/cordic_sample_gener_tb.vhd}
# vcom -reportprogress 300 -work work /home/kostya/Desktop/untitled folder/cordic_sample_gener/testbench/cordic_sample_gener_tb/simulation/cordic_sample_gener_tb.vhd
# -- Compiling entity cordic_sample_gener_tb
# -- Compiling architecture rtl of cordic_sample_gener_tb
Seems pretty clear to meOk,now I trying to compile all submodules files with tb file, its mean that i compile altera_avalon_clock_source.sv
verbosity_pkg.sv
but i have some errors and I really dont understand what does it means
vsim -L altera -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cycloneive_ver -L lpm -L sgate -L altera_mf -L altera_lnsim -L cycloneive work.cordic_generator_tb
# vsim
# Start time: 02:28:07 on Apr 19,2016
# Loading std.standard
# Loading std.textio(body)
# Loading ieee.std_logic_1164(body)
# Loading ieee.numeric_std(body)
# Loading work.cordic_generator_tb(rtl)
# Loading work.cordic_generator(rtl)
# Loading work.cordic_generator_nco_ii_0
# Loading altera_mf_ver.altshift_taps
# Loading lpm_ver.lpm_add_sub
# Loading lpm_ver.lpm_counter
# Loading sgate_ver.oper_add
# Loading sgate_ver.oper_mux
# Loading sv_std.std
# Loading work.verbosity_pkg
# Loading work.altera_avalon_clock_source
# Loading work.altera_conduit_bfm
# Loading work.altera_conduit_bfm_0002
# Loading work.altera_avalon_reset_source
# ** Warning: (vsim-3017) /home/kostya/bladeRF/hdl/quartus/cordic_generator/testbench/cordic_generator_tb/simulation/cordic_generator_nco_ii_0.vo(12986): [TFMPC] - Too few port connections. Expected 15, found 14.
# Region: /cordic_generator_tb/cordic_generator_inst/nco_ii_0/nlOOl
# ** Warning: (vsim-3722) /home/kostya/bladeRF/hdl/quartus/cordic_generator/testbench/cordic_generator_tb/simulation/cordic_generator_nco_ii_0.vo(12986): [TFMPC] - Missing connection for port 'eq'.
# ** Warning: (vsim-3934) /home/kostya/bladeRF/hdl/quartus/cordic_generator/testbench/cordic_generator_tb/simulation/cordic_generator_tb.vhd(102): [TFMPC] - Missing VHDL connection for formal Verilog port 'reset_n'.
# Region: /cordic_generator_tb/cordic_generator_inst_in_bfm
# ** Error: (vsim-3059) Cannot connect a VHDL array signal to Verilog scalar port 'sig_clken'.
# ** Warning: (vsim-3934) /home/kostya/bladeRF/hdl/quartus/cordic_generator/testbench/cordic_generator_tb/simulation/cordic_generator_tb.vhd(111): [TFMPC] - Missing VHDL connection for formal Verilog port 'reset_n'.
# Region: /cordic_generator_tb/cordic_generator_inst_out_bfm
# ** Error: (vsim-3059) Cannot connect a VHDL array signal to Verilog scalar port 'sig_out_valid'.
# Error loading design
clk,
reset,
reset_n,
sig_fsin_o,
sig_out_valid
cordic_sample_gener_inst_out_bfm : component altera_conduit_bfm_0002
port map (
clk => cordic_sample_gener_inst_clk_bfm_clk_clk, -- clk.clk
reset => cordic_sample_gener_inst_rst_bfm_reset_reset_ports_inv, -- reset.reset
sig_fsin_o => cordic_sample_gener_inst_out_fsin_o, -- conduit.fsin_o
sig_out_valid(0) => cordic_sample_gener_inst_out_out_valid -- .out_valid
