ammassk
Hi all
I wrote a vhdl code for file read. Its for getting array of integers from the file.To check whether this program working properly ,Ineed to write a testbench.Please help t write testbench for this code. I am using xilinx 10.1 version.I generated atestbench in this , but couldn't work out.
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 library ieee; use ieee.std_logic_1164.all; USE ieee.std_logic_arith.all; use ieee.numeric_std.all; library std; use std.textio.all; --use work.txt_util.all; entity lciread is port( CLK : in std_logic; -- RST : in std_logic; Y : out std_logic_vector(7 downto 0); EOG : out std_logic ); end lciread; architecture read_from_file of lciread is begin process(clk) file infile : TEXT; variable fstatus : file_open_status; variable l : line; variable temp: integer; constant prec:integer:=8; begin y<=(others=>'0'); --while reset = '1' loop file_open(fstatus, infile, "myfile.txt",READ_MODE); while (not endfile (infile)) loop if(clk='1' and clk'event) then readline (infile, l); read (l ,temp); y<=CONV_STD_LOGIC_VECTOR(temp,prec); end if; end loop; file_close (infile); --end loop; EOG <= '1'; end process; end read_from_file;
