Test bench for VHDL read from external file
ammassk
Member level 2
Hi all
I wrote a vhdl code for file read. Its for getting array of integers from the file.To check whether this program working properly ,Ineed to write a testbench.Please help t write testbench for this code. I am using xilinx 10.1 version.I generated atestbench in this , but couldn't work out.
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
library ieee;
use ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
use ieee.numeric_std.all;
library std;
use std.textio.all;
--use work.txt_util.all;
entity lciread is
  port(
       CLK              : in  std_logic;
--       RST              : in  std_logic;
       Y                : out std_logic_vector(7 downto 0);
       EOG              : out std_logic
end lciread;
architecture read_from_file of lciread is
begin
process(clk)
    file infile : TEXT;
    variable fstatus : file_open_status;
    variable l : line;
    variable temp: integer;
     constant prec:integer:=8;
    begin
        y<=(others=>'0');
        --while reset = '1' loop
            file_open(fstatus, infile, "myfile.txt",READ_MODE);
            while (not endfile (infile)) loop
                  if(clk='1' and clk'event) then
                    readline (infile, l);
                    read (l ,temp);
                    y<=CONV_STD_LOGIC_VECTOR(temp,prec);
                        end if;
            end loop;
            file_close (infile);
       --end loop;
          EOG <= '1';
     end process;
end read_from_file;
first of all:
you shouldnt use std_logic_arith and numeric_std in the same file. They have conflicts. The standard library is numeric_std.
Secondly - you havent said what problems you are having?
