TEST BENCH MODIFICATION HELP
Soh_bhat
Junior Member level 1
Hi there,
Can you check this top module and the test bench? I don't know if I am doing something wrong with the test bench or clock. Can you kindly help me modify it? The waveform is delivering the outputs correctly, but the output is split into two parts within a specific period. You can check the y_in and you can see there's two values in between the first x_in range. I want it to be in one range of x_in. Am I doing anything wrong with this code? Coz all the other modules are working perfectly fine as expected. Would be happy to share more details. Your help will be appreciated.
Top:
-- Company:
-- Engineer:
-- Create Date: 02/26/2023 07:30:53 PM
-- Design Name:
-- Module Name: Top - Behavioral
-- Project Name:
-- Target Devices:
-- Tool Versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx leaf cells in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity Top is
 Port (
 --clock: in std_logic;
 inst: in std_logic_vector(31 downto 0);
 cont: out std_logic_vector(31 downto 0);
 addr: out std_logic_vector(11 downto 0);
 x_out: out std_logic_vector(31 downto 0);
 y_out: out std_logic_vector(31 downto 0);
  x_in: out STD_LOGIC_VECTOR(31 downto 0);
  y_in : out STD_LOGIC_VECTOR(31 downto 0);
   h : out STD_LOGIC_VECTOR(31 downto 0);
  p_in : out STD_LOGIC_VECTOR(31 downto 0);
  p1_in : out STD_LOGIC_VECTOR(31 downto 0);
  c_in : out STD_LOGIC_VECTOR(31 downto 0);
  initial: out std_logic;
  initial_flag: out std_logic;
  cma_out: inout std_logic_vector(11 downto 0)
end Top;
architecture Behavioral of Top is
component Mem is
Port (
           cont: in std_logic_vector(31 downto 0);
           addr : in std_logic_vector(11 downto 0);
           write_en: in std_logic;
           flush : in std_logic;
           init: in std_logic;
           init_flag: in std_logic ;
           x_out: in STD_LOGIC_VECTOR(31 downto 0);
           y_out : in STD_LOGIC_VECTOR(31 downto 0);
           cma_out: inout STD_LOGIC_VECTOR(11 downto 0)
end component;
component reg is
Port (
        clk: in std_logic;
        rs1 : in std_logic_vector(4 downto 0);
        regwr : in std_logic;
        wrdata: out std_logic_vector(31 downto 0)
--        x_out : out std_logic_vector(31 downto 0);
--        y_out: out std_logic_vector(31 downto 0)
 end component;
component Control is
Port (
flush: out std_logic;
write_en: out std_logic;
init: out std_logic;
init_flag: out std_logic
end component;
component RKMod1 is
Port (
   x_in: in STD_LOGIC_VECTOR(31 downto 0);
           y_in : in STD_LOGIC_VECTOR(31 downto 0);
           h : in STD_LOGIC_VECTOR(31 downto 0);
           p_in : in STD_LOGIC_VECTOR(31 downto 0);
           p1_in : in STD_LOGIC_VECTOR(31 downto 0);
           c_in : in STD_LOGIC_VECTOR(31 downto 0);
           x_out: out STD_LOGIC_VECTOR(31 downto 0);
           y_out: out STD_LOGIC_VECTOR(31 downto 0)
           --clk : in std_logic
           --aclk: in std_logic
end component;
signal clock: std_logic := '1';
signal addr1: std_logic_vector(11 downto 0);
signal wdata:  std_logic_vector(31 downto 0);
signal  rs :  std_logic_vector(4 downto 0);
signal flush : std_logic;
signal write_en: std_logic;
signal   x_in1:  STD_LOGIC_VECTOR(31 downto 0);
signal  y_in1 :  STD_LOGIC_VECTOR(31 downto 0);
signal    h1 :  STD_LOGIC_VECTOR(31 downto 0);
signal  p_in1 :  STD_LOGIC_VECTOR(31 downto 0);
signal  p1_in1 :  STD_LOGIC_VECTOR(31 downto 0);
signal   c_in1 :  STD_LOGIC_VECTOR(31 downto 0);
signal x_output:  STD_LOGIC_VECTOR(31 downto 0);
signal y_output :  STD_LOGIC_VECTOR(31 downto 0);
signal init : std_logic;
signal  init_flag :  std_logic;
--signal inst:  std_logic_vector(31 downto 0);
signal clk_period: time := 10 ns;
begin
uut1: Mem port map (
cont => wdata,
addr => addr1,
write_en => write_en,
clock => clock,
init_flag => init_flag,
x_in => x_in1,
y_in => y_in1,
h => h1,
p_in => p_in1,
c_in => c_in1,
p1_in => p1_in1,
flush => flush,
init => init,
x_out => x_output,
y_out => y_output,
cma_out => cma_out
uut2: reg port map (
 clk => clock,
 rs1 => inst(19 downto 15),
 regwr => write_en,
 wrdata => wdata
uut3: Control port map (
inst => inst,
addr => addr1,
flush => flush,
init => init,
uut4: RKMod1 port map (
x_in => x_in1,
y_in => y_in1,
h => h1,
p_in => p_in1,
c_in => c_in1,
p1_in => p1_in1,
x_out => x_output,
y_out => y_output
clk_process rocess
  begin
     clock <= '0';
      wait for clk_period/2;
      clock <= '1';
  end process clk_process;
cont <= wdata;
addr1 <= inst(31 downto 20);
addr <= addr1;
initial <= init;
 x_in <= x_in1;
 y_in <= y_in1;
h <= h1;
c_in <= c_in1;
p_in <= p_in1;
p1_in <= p1_in1;
initial_flag <= init_flag;
x_out <= x_output;
y_out <= y_output;
end Behavioral;
Test bench:
-- Company:
-- Engineer:
-- Create Date: 02/26/2023 08:02:34 PM
-- Design Name:
-- Module Name: Top_TB - Behavioral
-- Project Name:
-- Target Devices:
-- Tool Versions:
-- Description:
-- Dependencies:
-- Revision:
library IEEE;
--library UNISIM;
entity Top_TB is
--  Port ( );
end Top_TB;
architecture Behavioral of Top_TB is
component Top is
 Port (
--  init_flag: in std_logic;
end component;
--signal clock: std_logic := '0';
signal cont:  std_logic_vector(31 downto 0);
signal  addr :  std_logic_vector(11 downto 0);
signal  initial_flag:  std_logic;
signal  x_in:  STD_LOGIC_VECTOR(31 downto 0);
signal            y_in :  STD_LOGIC_VECTOR(31 downto 0);
signal            h :  STD_LOGIC_VECTOR(31 downto 0);
signal            p_in :  STD_LOGIC_VECTOR(31 downto 0);
signal           p1_in :  STD_LOGIC_VECTOR(31 downto 0);
signal           c_in : STD_LOGIC_VECTOR(31 downto 0);
signal initial: std_logic;
signal cma_out:  std_logic_vector(11 downto 0);
signal  x_out:  STD_LOGIC_VECTOR(31 downto 0);
signal            y_out :  STD_LOGIC_VECTOR(31 downto 0);
constant clock_period : time := 10 ns;
begin
uut: Top port map (
--clock => clock,
inst => inst,
initial_flag => initial_flag,
cont => cont,
addr => addr,
x_in => x_in,
y_in => y_in,
h => h,
c_in => c_in,
p_in => p_in,
p1_in => p1_in,
initial => initial,
x_out => x_out,
y_out => y_out,
cma_out => cma_out
--clk_process rocess
--   begin
--     clock <= '0';
--      wait for clock_period/2;
--      clock <= '1';
--  end process clk_process;
stimulus: process
begin
--write_en <= '1';
inst <= "000000000000" &  "00001" & "000" & "00000" & "0001100"; --- RKI
wait for clock_period;
--write_en <= '1';
inst <= "000000000100" &  "00010" & "000" & "00000" & "0001100";
--write_en <= '1';
inst <= "000000001000" &  "00011" & "000" & "00000" & "0001100";
--write_en <= '1';
inst <= "000000001100" &  "00100" & "000" & "00000" & "0001100";
--write_en <= '1';
inst <= "000000010000" &  "00101" & "000" & "00000" & "0001100";
--write_en <= '1';
inst <= "000000010100" &  "00110" & "000" & "00000" & "0001100";
--wait for clock_period * 50.5;
inst <= "000000000000"  &  "00001" & "101" & "00000" & "0001100"; --- RKU (FLUSH)
wait for clock_period * 43.5;
--wait for clock_period * 14;
--wait for clock_period * 51;
inst <= "000000000000"  &  "00001" & "001" & "00000" & "0001100"; --- RKS
inst <= "000000000000"  &  "00001" & "100" & "00000" & "0001100";---RKU(UPDATE)
----wait for clock_period;
--wait for clock_period * 45;
--wait for clock_period * 20;
wait;
end process;
end Behavioral;
You are trying to run a design which has a clock input, but within the top module it is tied to '1'? o_O
If you do not have a good explanation for it, I am not looking any further!
And then as I scroll down the forum, I see a similar post from you:
....in which at least the clock could be seen toggling in the waveform (I did not read it as others were already in to it).
Creating multiple posts of the same problem will not fetch you better help!!!
Hi thanks for your reply. Actually, I don't have clock as an input port in the top module. I had tried to use clock as an input but unfortunately the problem did not go. So I used it as signal and instantiate it with the clock's of other modules. Although I have tried to put the clock value as 0. Point is that in the waveform, xin value is coming greatly. But the yin value is splitted in two parts. I think it's regarding the clock or clock period. But couldn't find where's the problem is. That's why posted over there. Could you please help me checking the test bench or the behavioral? Actually I also don't know if I am doing anything wrong with the clock. Please kindly help.
Listen, a design can be realized using....
1. Completely combinatorial logic
2. Completely sequential logic
3. A mixture of sequential & combinatorial logic
Now I do not know about your DUT. If they fall under the category of 2 or 3, your testbench must supply the clock.
--- Updated ---
You do have it, I see that the "clock" signal is commented out, why?
That's wrong debugging, how can you solve a problem within a sequential design by not toggling the clock?
LaTeX Commands Quick-Menu:
