Tanner Ledit problem !!!
wls
Member level 4
Singapore
tanner tools lservrc
Hello guys. I have problem with Tanner Ledit license server problem ? It is not connecting ?
Can anyone tell me what is " License error 1066 " means ?
Trying to contact server 10.1.4.75...
Failed to obtain version 11.0 license.
License error 1066. Please contact Tanner Technical Support at (626) 792-3000
or support@tanner.com.
Checking hardware lock...
Failed to obtain base license.
This feature was not found on this computer.
Environment variable LSERVRC=C:\WINDOWS\lservrc found.
The 'lservrc' file must have a valid license string for this feature.
licence l edit
Maybe your need to update the license!
If I'm not mistaken...
You need to have 'dongle' to run the tools...
Unless you are using the crack version...
8O
failed to obtain wls edit lock
I think the server license you had obtained is not compatible for TANNER Tools v11. Maybe it was generated for a lower version of TANNER. Try re-checking the specified license file path and look into the Iservc file. If you computer had been set as the server, the file could be obtained in the Windows directory.
Rgds
l edit 10.1 licensing
Hello. When i type/invoke lsmon it show the license features and when i invoke lswhere it shows the server name and ipaddress ( shown in the attachment ?
I check in the c:\windows , there are the lservrc file with lservrc bak folder ?
So , does that means license is valid or not ? How to check ?
Thx.
