eugenesiew
t610 at command
hi all
i have seen many topics discussed in this forum using super old model of hp for sms controller. Unfortunately i have spend my last whole month trying to obtain those super old models like ericssonT10s, T18s, 688, or siemens C25/S25 and the result was miserable.... most of the shops in my country said that those models have long be gone... recently i bought a T10s from the internet and it couldnt work at all... wasted quite a sum of money there...
i source some website which was found using the T10s as sms controller, the only main two pins tapped out were the RX and TX or also known as the data in and data out pins. hence i thought it would be theorectically possible to build one using other sony ercisson model as long as they support AT commands and have the data in and data out pins (RX and TX)...
Has anyone has tried building a sms controller (simple one, just to turn on/off 4 LEDs) using either the sony ericsson T610 or T630?
i understand that both of the above mention models supports SMS in both text mode and PDU mode.
can anyone please confirm whether it is possible to implement before i get one and try it out? do send it any related useful website using the T610 and T630 as a sms controller...
lastly, between T610 and T630, are there any difference in implementing? or in lame men terms, which is easier to be implemented? i guess they are the same since they were manufactured almost about the similar time... anyway, do give your opinions, they are very much needed
thanks!
hi all
thanks!
