no i did not copied from anywhere..r u going to buy new cellphone??eugenesiew said:thanks for the reply... you did this based on any website or you design the circuit yourself? isn't t610 newer than t290i? theorectically is should be able to be done too right? what's your point of view? cause only t610 and t630 are only available at my region...thanks!
eugenesiew said:i just bought T630 la... the previous post said that t630 is newer and better? why do you say i would be wasting my time?? i really need all you experts out there... cause havent tried this before.. thanks!
at
OK
at+cmgf=?
+CMGF: (0,1)
OK
at+cmgf=1
OK
response from hyperterminal... it shows that it can support sms in text mode... but then the at command online reference from sony ericsson itself only says it has pdu mode... weird huh? but some other people had told me that it may support sms in text mode... anyone here able to suggest? thanks again
abbas1707 said:if u got that output........then it clearly shows T630 supports text mode,,,,, but what about auto baud rate detect:idea::idea::idea::idea::idea::idea:
