yushionly
Junior Member level 2
I am a new user,when i use design compiler for synthesis a simple full adder example, the result got me puzzled.
result:
Point Incr Path
clock clk (rise edge) 0.00 0.00
clock network delay (ideal) 0.00 0.00
input external delay 0.00 0.00 r
ci (in) 0.00 0.00 r
U9/Y (XNOR3X4) 0.83 0.83 r
U10/Y (CLKINVX20) 1.48 2.31 f
s (out) 0.00 2.31 f
data arrival time 2.31
why the time delay is so long? 2.31ns? anyone could explain it?thanks!
code:
module adder(a,b,ci,s,co);
input a,b,ci;
output s,co;
assign s=(a&(~ci)&(~b))|(a&b&ci)|((~a)&(~ci)&b)|((~a)&(~b)&ci);
assign co=(a&b)|(a&ci)|(b&ci);
endmodule
constrain.tcl:
# specify your logic delay here (in nanosecend)
set DELAY 0
set CLK "clk"; #virtual clock name
create_clock -name $CLK -period $DELAY
set MAX_LOAD [load_of umc18io3v5v_slow/P8A/P]
set_input_delay 0 -clock $CLK [all_inputs]
set_driving_cell -lib_cell P8A -pin P [all_inputs]
set_max_capacitance $MAX_LOAD [all_inputs]
set_output_delay 0 -clock $CLK [all_outputs]
set_load [expr $MAX_LOAD * 2] [all_outputs]
set_max_area 0
set_operating_conditions -max "slow" -max_library "slow" -min "fast" -min_library "fast"
set auto_wire_load_selection false
set_wire_load_model -name umc18_wl20 -library slow
set_wire_load_mode top
result:
Point Incr Path
ci (in) 0.00 0.00 r
s (out) 0.00 2.31 f
code:
input a,b,ci;
output s,co;
endmodule
constrain.tcl:
set DELAY 0
set_max_area 0
