set target_library "corelib_wc.db corelib_bc.db"
set link_library "* $target_library"
search path is where these files are present
have u used the above mentioned target library that's where ur actual synth takes place
Added after 1 minutes:
search path is where these files are present like 2005.09 directory
if u haven't used it doesn't get the technology file and stops at gtech level
and ur .sdb file is not required if ur not willing to look at the symbols graphically.
