Synopsys Design Compiler
njr@1
Junior Member level 2
Dear all
When I try to synthesis the Design ware example in DC and give the clk some period why am I not able to see the clk period in the timing report or the report_qor! it says critical path slack as uninit and critical psth clk period as n/a !
Please let me know.
Thank you
create_clock "clk" -period 5 [get_ports clk] in this way.
This is correct. But are you know whether there are valid paths within the design that use this clock?
yes. There are valid path.
Then you can try a report_timing command on a valid path..See what it reports..
