Clunixchit
Member level 1
Hello,
I use in my internal scripts the design names (the last column) from report_area -hierarchy. However with the versions A-2007.12-SP2 and A-2007.12-SP3 their naming rules have changed. Hence my scripts are broken.
Example:
DC versions below A-2007.12-SP2 : a particular design name is TIMER_2_test_1
now with A-2007.12-SP2 and A-2007.12-SP3 its design name is TIMER_2
Since for my TCL scripts, TIMER_2 is not TIMER_2_test_1
Is there a compatibility variable to set to true or false, in order to use the old convensions ?
Example:
