May 24, 2018 #1 E electronicsengineertry Newbie level 1 Joined May 24, 2018 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1 Activity points 9 Dear All, I have been working on switching ON/OFF two devices using Traic which are opto-triac driven. So far ON/OFF is working fine. My schematic is as attached. The problem is when I switch ON Lamp 1 - and keep Lamp 2 OFF , still I get (120V between Line and Neutral) If I switch OFF Lamp 1 - the voltage goes off. Can you please suggest what I might have missed? Last edited by a moderator: May 24, 2018
May 24, 2018 #2 KlausST Advanced Member level 7 Joined Apr 17, 2014 Messages 25,161 Helped 4,868 Reputation 9,757 Reaction score 5,537 Trophy points 1,393 Activity points 168,359 Hi, still I get (120V between Line and Neutral) Click to expand... Between Line (L) and Neutral (N) there should be 220V continously, independent of lamp status. I assume the voltage you measure is elsewhere. --> Please show where you measure the voltage. Additionally post a photo of your circuit. Klaus
May 24, 2018 #3 E Easy peasy Advanced Member level 6 Joined Aug 15, 2015 Messages 4,747 Helped 1,402 Reputation 2,804 Reaction score 1,933 Trophy points 1,393 Location Melbourne Activity points 26,225 Also, your schematic is wrong - it shows the gate shorted out to MT1...
